Unique use question
nofd843
Newbie
1
0
US Florida
I have a sailboat and I am looking at installing a set of spreader lights, while browsing one of the many emergency light provider sites I came up with the idea of using body mounted LEDs.
My question is this, which LED would be recommended for use at a height of about 10-11 ft above the deck? I will be using clear and it will be used in the steady mode. These lights are used at night when needing to perform work on deck. Any suggestions would be appreciated while I research this idea.
Thanks
J
I sell a LED work light for $60.
Call me Monday if you are interested - 1-866-486-6177
4" Round LED Work Lamp
o 20,000 hour burn time
o 1300 Lumen
o Six, 3w high intensity LED = 18 watts of light
o Current draw 1.5A @ 12V
o Input voltage 10-30V DC
o Wide flood beam pattern
o Clear poly lens
o Die cast aluminum housing
o Variety of mounts included
o Waterproof
o Dimensions: 128mm×φ116mm×44mm
Mluna53
