Vertex question
Sep 13, 2010
761
Holland, Michigan
Curious how many vertex can be hooked together in series? I have a guy who is looking to replace his strobes with leds. I am curious to get these to sync right without a external flasher would I be able to get 8 of them to hook together and flash correctly? 2 of them are going in red strobe housings and the other 6 are going in head light running light and fog lights.
Otherwise I was thinking of Xing the outter 4 (headlights and fog lights) then having the 2 in the running lights and the 2 in the red housing alternating. Like the 2 in the housings flash together and then the 2 in the running lights together.
Also he has all clear minus the 2 red housings and I was thinking of adding some more red to the mix. Kind of so its not so blinding. Its a 04 chevy silverado. Where might you guys add more red in the lights? He can only have red clear and amber. He does plow so I am not opposed to amber in the front.
Sirennet
210
Oregon
You can connect up to 12 Whelen Lightheads using just the sync wire.
htamboli
