Vertex wiring in Ford Escape?!?
KRC845
95
Newcastle, OK
Which would be the best way to route the cables from the vertexs into the vehicle from the tail light assembly since the entire housing is outside of the vehicle?
KRC845
95
Newcastle, OK
The existing wiring from the tail lights seemed to be under the vehicle. I only had a short time to play earlier tonight but I will get this worked out tomorrow.
towlercd
55
Potsdam, NY USA
I did an older model (2002) by drilling a hole through the sheet metal behind the light and then using a small grommet/silicone. There is just an empty void behind it that you can then use to route the wire up or down.
KRC845
95
Newcastle, OK
I routed the wire up above the tail light following the black seal for the hatch to the top/center of the the seal and ran the wires through an existing hole thats used for the third brake light.
la_canuck
