Does anyone know if there’s a way to access some of the Whelen core CAN features for a vehicle that isn’t supported by whelen? Want to park kill, vehicle lock/unlock, etc.
Adapting unlisted vehicles is always a challenge. If you can map out the OBD2 port you might be able to adapt a CANport from another vehicle, but it's going to be trial and error. I found this online for 1996 Nissans onward.2020 Nissan frontier
ScanPort is the only cable that will work with that truck. Well, kind of. The K9 cable will work on some 23 silverados, but they changed everything mid year. So if you have to order a cable, get the scanport. Scanport will work on any Command supported vehicle.Does anyone have experience with the scanport module whelen put out? We're trying to get a core system to work on a 2023 2500hd silverado, but found the obdii harness is not compatible to this truck.
We have a scanport, but the passenger seat module does not have the wires that whelen says to use ( CAN H Blue -CAN L White). We have identified a pair of Can H&L wires under the front row center jump seat. we are going to attempt to put the scanport there and see if we can get anything. Do you happen to know where others might be installing the scanport on these trucks?? Whelen has not been helpful they told us to contact chevy talked to 2 reps at whelen. Thank youScanPort is the only cable that will work with that truck. Well, kind of. The K9 cable will work on some 23 silverados, but they changed everything mid year. So if you have to order a cable, get the scanport. Scanport will work on any Command supported vehicle.
I haven’t installed one in an HD yet, and don’t know of any others. Are the colors just wrong? Or is it a stripped down model that doesn’t have the occupancy sensor?We have a scanport, but the passenger seat module does not have the wires that whelen says to use ( CAN H Blue -CAN L White). We have identified a pair of Can H&L wires under the front row center jump seat. we are going to attempt to put the scanport there and see if we can get anything. Do you happen to know where others might be installing the scanport on these trucks?? Whelen has not been helpful they told us to contact chevy talked to 2 reps at whelen. Thank you
Installed 2 Scanports on 2023 Tahoes and they work well.Does anyone have experience with the scanport module whelen put out? We're trying to get a core system to work on a 2023 2500hd silverado, but found the obdii harness is not compatible to this truck.
