Whelen lightbar mounting kits
Retired1
1,912
Woodward County, OK
I just purchased a 2011 Chevy Silverado 1500WT (Work truck), 4WD, standard cab, longer bed. I want to install one of my full-size Whelen Liberty lightbars on it. I am unable to locate a Whelen part number for the mounting hardware. Can someone give me the part number for the brackets that are attached behind the weatherstrip at the top of the doors? I have a set from my 2005 Tahoe (325 miles away at the moment) . Are they the same part as the 2011 Silverado mounting brackets?
Retired1
1,912
Woodward County, OK
code4services.com said:
I think it is strap kit #71. Whelen lists this kit for 52"-55" bars. Not sure if it will work on a 48".
Thanks, Jared
Do you know if this is the same part number as the kit for a 2005 Tahoe?
Terry
Retired1
1,912
Woodward County, OK
See the edit above, I was dyslexic for a minute. :D
The mounts appear to change in 2007 and up so your 05's will be wrong/different.
Got it - thank you again
Retired1
1,912
Woodward County, OK
I'm using a 48.5" Ultra Freedom (roof mounted) and a 48.5" Liberty (toolbox mounted).
Actually, I am going for maximum 'overkill' (using multiple lightbars and multiple beacons, mini-lightbars, and individual LED heads). When done it will surpass my previous 'over the top' lightshow. But, in direct answer to your question, the answer is 48.5" This size worked well on my 2005 Tahoe and I am going with it on the 2011 1500WT.
woobatu
