WHELEN LIN4s
TNFF412N
387
0
San Antonio, Texas
I have 4 LIN4s that have been sent to Whelen to be repaired for moisture issues, i am about to install some more lights and noticed that all of them are having issues again.... I Am getting fed up with this. My lin3 and tir 3 dont have these issues, Is it wrong for me to request that they replace these with something else? i dont mind going to Tir3s i am just getting fed up with having to remove them yet again...
The lin4's suck in terms of moisture problems! Lin4's always seem to be the one light head that draws in moisture!! I would send them in and request that they replace with with linz6's!
I sent four lin4's back to Whelen with the same problem, was told that they are replacing
them with linz6s. Well thats a total lie, as I was sent back brand new lin 4's and I was
told they have plenty to replace. I really did'nt care for the over rated linz6's and was glad
to get brand new sets of lin4's as I found spitfire housings and am using as inner edges
inside of the vehicle as I would never use another whelen leds outside, I can't afford
to keep sending leds back to Whelen that was mounted on the outside. My suggestion
is too send them in again, once you get them back use them on the inside of the
vehicle. If Whelen was to replace my lin4's with the linz6's I would trade them off and
use my pods. :mrgreen: Also the justice bars are just as bad for drawing moisture.
You think that the ONCE light king would find a solution, but thats why so many people
are finding other leds from other companys, less hassles of replacing Whelens leds.
Jim Rogers
Northern Lights/Sirens
its wrong in the sense they are probably not going to send you back a different model !!!
few weeks ago, i bought a set of lin4 on ebay... turns out they didnt even turn on......
sent them in... 2 days later i had a new set.......
I was told this morning that they have a limited amount of red Lin 4s, not enough to replace mine so they said I'm getting linz6 which happy about since I haven't heard issues with them leaking
I was told the same thing, but the red lin 4's showed up from whelen when I received them
back. So what I am doing is looking for spit fire housings and turning them into spilt fire dash
light,inside side lighting of the vehicle so I don't run into problem again. Actually I am glad they
send back the lin4's and not the over rated linz6's.My plans was to trade off the linz6's if
they were send back in place of the lin4's. But all is happy on the home front.
Jim Rogers
deputychief301
t_gibson
