Whelen Rotabeams
kohan25
112
Oxford, CT.
Those are really fast motors. Are those 12 v? 6v will do that when you hook them to 12 v.
They are 12 volt. I had a couple of 24 volt rotabeams so i swapped the motors with 75rpm motors which is what i had ( i think standard are 33rpm) I have one with a 55rpm motor which looks the best.
kohan25
112
Oxford, CT.
Dan
I believe i got the motors from you awhile back. They are 75rpm and i have a 55rpm. Tried to contact you before but we never connected. Let me know a good time to call. i work 3rd shift and weekends so i try to get sleep when normal people are up.
Wailer
2,293
Canada
I didn't know they came in that many different sizes. The light assembly in the largest one reminds me of the junior Beacon Ray.
dmathieu
May 20, 2010
8,781
S.W. New Hampshire, USA
Actually, the glass lenses in the smaller Whelen Rota-Beams are almost exactly the same as those in the Junior Beacon Ray, almost interchangable. The Senior Rota-Beam's lenses are much larger. All of the Rota-Beams have 3 lenses in the lens cage, the Junior Beacon Ray has 4.
Reactions: OliverD
CrownVic97
Hazen, ND
Wailer
2,293
Canada
So how do the sizes of the various Rota-beam lights compare to the Beacon Ray 17 and Junior Beacon Ray? Is the largest Rota-beam bigger than a Junior but smaller than a 17?
helmi
