Does anyone have, or know where there is, a schematic for a Whelen passive single talon...? I'm trying to get one that I have to work... The main problem looks like the "jump pin" looking connector is broken, but if I can find out what pin does what I can make it work...
Here's a pic of the back of the board. The "jump pin" that I'm talking about is at the lower right hand corner. There are 4 pins that come from the back of the lighthead board, through the heat sink, then into the pictured power board.
Also the pattern select button (the square block on the left side in the middle) is busted out... To change the flash pattern (if and when I get it working), I would just need to jump across the contacts in the button housing, correct...?
Any help would be appreciated... Thanks guys!!!
- Tim
- Tim
