Whelen Traffic Adviser Controllers
jacobm
40
SW Idaho
All gone! Thanks to all who bought from me!
5 2 Whelen TACDTL1 Traffic Adviser controllers. 4 are pictured, I found a fifth one after taking the pictures. All have all their wiring attached. Asking $40 shipped each.
Reactions: Lcroewer
jacobm
40
SW Idaho
It looks like the Freedom uses a 2-wire TA system, so it should work if that's how yours is set up. PM me for more.
May 23, 2013
458
nc
wished this would work a 8 head traffic advisor like the whelen controller i have does
jacobm
40
SW Idaho
Sold to: nlaser11
Sold to: Tritonhoward64
3 left, one needs a ground cable which I will try to track down and install.
buickid
4
Honolulu, HI
These just apply straight +12V to the outputs when switched on right? I'm guessing pressing the Scan-Lock button with a small screwdriver/paperclip just applies +12V to the Scan-Lock wire going to the TA?  If so, it should work just fine with my SoundOff Signal TA, which just needs +12V applied one of four wires for left/right/warning, and a momentary +12V applied to a "pattern select" wire when setting it up, which would connect to the Scan-Lock wire.  In other words, there isn't any fancy switching circuitry in the controller itself, it's just a box of switches, right?.  If anyone else thinks this would probably work, I'll take one!
Instinq
