which switch for which function?
aj9j
35
northern Wells county, IN
Hello,
I am setting up my old ford f150 pickup 1993, I do roadside rescue, ie stranded motorist so my primary lighting is to rear of vehicle, so here is what i have on truck,
I am using a Code 3 V-CON switch box has 3 way pursuit switch.
now for lighting,
jetstream 3 rotator lightbar amber.
rear facing wig-wag in jetstream, optional wig wags can be turned on to steady mode with switch #8.
top of tool box a fs 6 head arrowstick which is set just as flashing unit, no controller for it,optional can be steady burn on switch #7.
corner strobes,
dual head code 3 strobe on dash.
so my ? is which iteams do you all suggest go to which switch.
1
2.
3.
4.
5 is momentary switch. maybe good for air horn?this way when I got the box!
6.
7. steady burn stick.
8. steady burn wig-wag.
i could put both steady on one switch but lose some flexability,
thanks for looking and responding. :)
yeah im gonna need a good chair and some popcorn for this thread...
:lol:
EVModules
864
Deer Park, WA
Truth be told, all you need is two switches, one for rear flash and another for rotators. If you have work lights, add another switch.
wdhurley
Lexington, SC
+1. More switches doesn't make you any more effective. do what we do on our installs. First slide position is rear/sides, second slide is front, and third is your whites. works great for when you pull up on a scene so you're not blinding the people in front of you.
JBM533
