Wiring a boat
amccullers
Premium Member
575
Wetumpka, Alabama
I will be putting a siren and edge bar on a Rscue 1 boat. Is there anything special I need to be aware of? What siren and switches would be best? Pictures will follow in the install thread.
Thanks Andrew
Salt water or fresh water use?
And it basically all boils down to.. Use marine switches, waterproof all connections (or mount in areas where it won't get damp/wet)
Never done a siren on a boat, but I think some companies make a "standard" two tone marine siren, IIRC.
Also, generally you can NOT ground to the chassis on a boat. All grounds have to go back to the negative battery terminal.
Thanks for the help so far. It will be used in fresh water. Our marine police around here have sirens on there boats, and I think they would use the PA part more than anything else. Its for a neighboring dept that has alot of lake front territory
You may want to consider a Marine radio with "loud hailer" option (which are quite common on larger vessels) and a electronic marine airhorn with the lights...?
Depends on the size and material the boat is made of... On small crafts, though, I give it to you, return to the neg terminal...
definitely bring all grounds back to the battery as stated. depends on the boat (center console, etc) most emergency boats ive seen either have indoor area or at least a compartment above or below the center console where you would mount the equipment. Other then that is pretty much straightforward. Oh and mount the siren speaker relatively high or the sound echoes too much. Nothing special is need really as sounds travels like crazy on water.
Also dont forget to make sure you have clearance if you put any screws in. Nothing worse than putting a screw through a hull or gas tank.
gabyluis_1
