Wooo-Hoooo !!!
So you're the one bidding against me! I figured as much. You got a good deal on those Bob! I headed over here right after the auction to see who was going to brag!!!!
I wasn't actually bidding.
I had the starting bid that lasted for the duration of the auction untill there was about 4 hours left, Then I sniped them with Ebay's Auction Sniper.
I wasn't bragging (ok maybe a little), but now I will:
I also won the Signal Stat 377 "Hill Light" with the rare clear dome. A little pricey, but somebody else was bidding every 20 seconds. My competetor bid 16 times on that light...I sniped it :cool:
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWNX%3AIT
A question on the Signal Stat 377. I'm not familiar with that model, but based on the lamp holder it appears that there is one lamp angled up at about 10 or 15 degrees, the other three are level, is this correct?
I think you got a steal on the S&M 757's.
The Signal Stat 377 was designed as a "hill light" style beacon, with one bulb tilted up, and the opposite bulb tilted down.
The Deitz 211/711 "hill light", which looks very much like the Sig Stat 377, has just one bulb tilted up, and the other three are level.
I am sure that when the bulbs in this 377 were changed, they put the top back on wrong, which is why none of them look tilted. I think the offset top must be lined up correctly with the offset bottom for the bulbs to be angled up and down.
This light should have 7400 bulbs, instead of the 4416's that are in there.
How about some better pictures once you get it? By the way, my Dietz 711 "hill light" has one bulb 45 degrees up tilt, the opposite bulb is 15 degrees down tilt.
The early Signal-Stat lights from the '70s, that this version belongs to, used 4416.
Signal-Stat changed to 7400 later.
I think that you can use which ever you want.
In the mounting instructions I have for other Signal-Stat lights they state both sealed beams as replacements.
I have a never used early Signal-Stat 350 with one Westinghouse 4416 and one GE 7400.
If this is a factory fault or if it has been replaced later I do not know.
By the way, if you need mounting feets for the S&M light, John Dorgan has new ones.
My S&M 757 can lights arrived today.
They are 100% comlplete and dent free. These will be an easy restoration...glass bead blast, and powder coat.
The seller listed them as 24volt, but they had four 12volt amber 4412A GE bulbs in them, and all lit up when I applied power and ground.
This is my fourth set of can lights now, and every set had slight difference to them. These have a brass grounding bar that screws to the back of the bulb, then goes out to the side of the light and catches one of the bulb locator cutouts. Very unusual way to ground a bulb, but I have seen it before in the square style Yankee fog lights.
I'll get pic's up soon.
Dstewart02
