joeparv
joeparv said:And the bottom pic there's other wires next to the radio one.
shues said:The black cable with seven wires is from a Code 3 ArrowStik.
ERM said:You have to connect the blue, yellow, red and black wires in order for your headlights operate properly. By connecting the red and black wires, the circuit becomes active and monitors the blue wire for a high beam input. When a high beam input is present, the relay for the yellow wire activates. If your red or black wire were not connected, the pax headlight would not light.
By connecting the orange wire, the flasher circuit is activated while the high beam switch is in the off position. If the high beams were to go high while the flasher is on, then the flasher will stop flashing and both headlights will be steady until the high beams are deactivated. Let me know if you need any more explanation.
Tony
joeparv said:It's all connected. Passenger side highbeam does not work when I turn in highbeams. Everything is connected I believe except for the power n the wire for a switch. So I gotta find that wire hook it to a switch hook the power wire up to the battery and then once that's done just flip the switch and they'll begin flashing?
ERM said:As I said, the red wire must be connected to the flasher in order for the pax side light to work. The orange wire will only make the lights flash, but the red is needed to power the flasher and run its code of monitoring the blue wire and activating the yellow wire for both headlights to come on. Connect the red wire and everything will work normally.
Tony
joeparv said:Ok so orange would be my switch? Can use a normal toggle so power acc n ground to the switch. And make sure that the red wire from the unit is connected to the battery. So once I connect the red wire to the battery the passenger side highbeams will work finally? Normally they both work its just the highbeam On the passenger side that doesn't work because the red wire isn't connected to 12v. So once I power that up my light will work n then to flash I have to connect orange to a switch. Thanks alot man I really appreciate it lol
unlisted said:I think if you cannot figure it out with explanations here, and via the install manual, you should have someone who knows what they are doing install/complete it for you. (and watch them so you can learn)
jrfive0 said:I put vertexes in about the 5 o'clock position relative to the where the reverse light bulb goes in your picture, there is a circle already there if you look.
jrfive0 said:nope not at all, i used whelen vertexes in the two crown vics i just did, i cant see the code3's being that much different
joeparv said:It's not that I can't do it. It's just figuring out where the wires run to n what's what. There's alot of wire still and what they did was just cut em so gotta trace em back to their source. Thanks tho I appreciate all the help
Kd8bao said:The new Feniex Cannon dual color would have gone into existing hole. Mode 1 would be reverse lights and mode 2 would be warning. Similar to how I did my fog lights...
joeparv said:Was thinking about getting a pair of those. But was prob gonna wait til the 3 came out instead.
Yes Sir. Whelen made the HALO system that was the only system approved by DOT, FMCSA, or some other federal dept.(can't remember which one) that could replace the OEM lights. The approval was only for the CVPI though if I am not mistaken.FireEMSPolice said:Didnt Whelen or someone make lights that go in the socket for the OEM lighting assembly?
hitman38367 said:Yes Sir. Whelen made the HALO system that was the only system approved by DOT, FMCSA, or some other federal dept.(can't remember which one) that could replace the OEM lights. The approval was only for the CVPI though if I am not mistaken.
yes they are!!! I have a 4 bulb set for the taillights of the Tahoe I am getting and I also have a 2 bulb set that I will be modifying the DRL spots on the Tahoe for. (kinda like Cajun did with the Batmobile but all red. lol!!!) :thumbsup:unlisted said:and they are freaking AWESOME! (even in non DOT approved vehicles.. ahem) :thumbsup:
