Wilson LED conversions - multiple models and repair
Mrlunchbox
1,293
Central, MA
Thanks Ryan! I'll let you know. When I bought the legend a few days ago I didn't know until researching on FS website that it has a built in traffic adviser. If that is really the case then more than likely i'll end up selling the stick. I am curious though if the legend modules can be changed over. I am pretty sure they are solaris modules, correct?
rwo978
ND, USA
They are solaris. But, they look like this:
[Broken External Image]:http://www.zips.com/images/uploads/store/lgdupk_a_001_1_web.jpg
Not this:
[Broken External Image]:http://www.tlsemergencyequipment.com/images/006(17).jpg
wilsonbr90
1,427
Corning, New York
As long as I can access the diodes. Can I physically get to the diode. If so then it shouldn't be a problem
Mrlunchbox
1,293
Central, MA
Ok cool Just curious but what is your best guess as to where you think the diode might be? When I get the bar ill take it apart and send it to ya for assessment! :)
Mrlunchbox
1,293
Central, MA
Here is more info from the F/S website about there modules.
Federal Signal's technologies that have had a powerful impact include the Solaris® LED reflector design and ROC technology. Solaris maximizes the light performance of the most intense LEDs available and disperses the light where it is needed most. Federal Signal's patented ROC (Reliable Onboard Circuity®) technology eliminates approximately 85 percent of the connection failure points found in a typical lightbar. Wires, connections, and assemblies have been replaced in lightbars by PCB assemblies -- reducing labor repair time and increasing road time for emergency vehicles
wilsonbr90
1,427
Corning, New York
Diodes should be facing out. Easy as that.
rwo978
ND, USA
Diodes are facing up, into the reflector. It appears the reflector is removable by taking off the one hex screw/bolt, but unk if it's epoxied onto the board.
wilsonbr90
1,427
Corning, New York
Mrlunchbox said:
Well I guess we will find out! Hopefully it will work in my favor. LoL. :)
That's exactly right. Its a learning experience for both parties. I try to do my best. If there's a chance of damage I will let you know ahead of time before I proceed. I'm here to provide a service and start a side hobby.
Zapp Brannigan
May 23, 2010
3,580
I just need to find a padded/bubble wrap envelope so I can send out my lights to be upgraded. Can't wait!
wilsonbr90
1,427
Corning, New York
Just stocked up on leds and I have next week off from work. Will be able to do about a 24hr turnaround time for people who want stuff done fast. Trying to line up as much as I can. Thanks again for all the business guys. Keeps me sane.
Zapp Brannigan
May 23, 2010
3,580
medic550 said:
Could you pm with your shipping. Can talon heads be converted? What about dominator tir3 heads 2 wire?
Thanks
The answer to two of your questions are answered in the very first post!
http://elightbars.org/forums/f99/whelen-light-emitting-diode-conversions-multiple-models-56239/#post429432
wilsonbr90 said:
Led conversion, population, and replacement of burnt out diodes!
No more replacing a head after a section Burns out and either throwing away or putting it in a box never to be used again.
Pricelist for whelen lights
First off, Burnt out diode/section- $2 a module + $2 a diode
Avenger/ Dominators/ Talons with linear heads- $10 a module changed.
TIR3/ CON3- $6
rwo978
ND, USA
TIR3/LIN3s are sealed, and nearly impossible to break into.
On that note, it is possible... but there's a high likelihood of damage to the head. I had a non-functioning old style metal flange TIR3 that I was able to get into last night, but it was extremely difficult. It's sealed all around the border to nearly 1/2 inch deep, bordered by the circuit board. Go too deep, and you damage the circuits. Once inside, the LEDs are the same/similar to the round units on the older TIR6s/LIN6s/Liberty corners. There's a 4 pin plug, similar to the passive Talon plug, to which the LED board attaches to the flasher board. I was able to remove the LED board, and re-solder on the receptacle of the 4 pin plug, the solder had broke. It was PITA, but I was able to get the TIR3 functioning again. It's no longer water proof, but I keep a junky light around as a 12 volt tester, which this would be perfect for, or in a display unit, as there's no damage to the front. Plus, the metal flange covers up most of the nicks/cuts into the plastic I made breaking into it.
As to the new style plastic flange TIR3/LIN3s, I'm not sure I would attempt this on them.
Retired1
1,912
Woodward County, OK
I just sent four Freedom corners (with diffuser bars) in for a color change. I will post before and after photos when I receive the repopulated modules.
rwo978
ND, USA
Here's pics of a converted InnerEdge passenger side. Cards before were a mix of red & blue, with some of the blue only working dimly. They all came back working great!! Brightness is as bright as the cards beforehand. My quest for amber InnerEdge cards ends!!!!!!
wilsonbr90
1,427
Corning, New York
Looks like tir6 inners with linear corners. If somebody knows more than that chime in. If my statement is true, then yes shouldn't be a problem:thumbup:
MEVS06
3,485
San Antonio, TX
Mrlunchbox said:
I really need to send my boards from my legend to you... I'm dying to see if they can be changed!
So am I!!! If they can I know what I am doing to my 53" Legend...
I just got the package sent out today and forgot to put a message in the box. I'll just email it to you. Thanks
Retired1
1,912
Woodward County, OK
I just had a new 23" mini-Century pass through my hands. You are correct.
Zapp Brannigan
May 23, 2010
3,580
Got my first batch packed up and ready to send! Line at the post office was too long this morning or I would have sent today!
Mrlunchbox
1,293
Central, MA
I don't remember if this has been asked before or not, but can you make LED's dual color? As in flash one color then activate another? IE have red leds but flip a switch to make them TD's or floods?
wilsonbr90
1,427
Corning, New York
Not per say.
I'm some heads its possible to make them dual color red/blue but that would require another flasher on your part and extra wiring. As far as throwing white in to the mix that's touchy. I can't get ahold of color and white diodes in the same mix. I could possibly however do a Lin/tir6 where half are color and the other half white and rewire it to be able to run the white on a switch.
I may have to give it a whirl.
wilsonbr90
1,427
Corning, New York
Smart or dumb 400? The 6 over 6 have seperate leads to fire the top or bottom. I can do the top one color and the bottom white then all you have to do is wire an auxiliary input in to that leg to turn them on.
Am I understanding you correctly?
Mrlunchbox
1,293
Central, MA
wilsonbr90 said:
Smart or dumb 400? The 6 over 6 have separate leads to fire the top or bottom. I can do the top one color and the bottom white then all you have to do is wire an auxiliary input in to that leg to turn them on.
ohhhh Good question... I'm thinking of making a custom mini freedom. So id assume they are dumb modules. I think having red over white would be great! So you are saying that is possible?? Would love to have them be steady burn and flash capable. Or at the very least flash independently of the red leds.
shues
NW Indiana
The 400-series 6-over-6 modules found in the Freedom have two steady-burn segments, each with its own 2-place AMP connector for power and ground. Even those modules that are the same color on the top and bottom are this way. Red over white 400-series Freedom modules are already available, but because the optics that are designed to diffuse the light in a wide pattern, they aren't very good for use as a takedown.
wilsonbr90
1,427
Corning, New York
Put a flasher in line with it. That way you can flash or steady burn. Still trying to figure out exactly what you want. From my angle I'm pretty sure you can do what you want it to...
woobatu
