2005 Ford F-150 - - FINAL UPDATE (being retired)
Storm4200
2,912
NJ
Marc M said:
Cool. Any chance you could shoot me a pic of it sometime?
yeah im gonna take them down again to paint them. ill get a pic then. (its gonna be a while, im moving into a new house on thurs)
im also working on a decent quality 360degree video
Marc M
Georgia
Thanks. I hate moving.
Storm4200
2,912
NJ
heres a new HD walk around video...
Dont mind the wind noise as i havnt figured out how to replace it with terrible music yet....
The front is set up to convey a sense of urgency while in mode 3, The ILS as with the intersection lights are set to a rapid,attention grabbing pattern. The Grill lights flash on a SigAlert75 pattern to show clear flashing from a distance. Mode 3 can be used with or without forward facing WHITE. Drop it down to Slide switch 2 for more of an 'on-scene' (theres a video of that a few posts above). The rear lights are intended to be clear, precise and easy to understand, without blinding the approaching traffic. Because the patterns are slow, theres a lot of 'On-time'. Theres also the equally important, but frequently forgotten, 'Off-time'. They profile the width of the vehicle and include "3 levels" of warning. The lights use a combination of TIR and LIN reflectors and have proven very effective at a distance as well as up close and off-axis.
The Tomars on the sides of the toolbox and sides of the push bumper wernt my first choice, but im very happy with them.
Let me know what you guys think...
acala91
1,662
FL
I love everything about that truck, it looks great. The only thing I would change is the intersection lights. As mentioned earlier, a set of M4s would be perfect, or even some surface mount Intersectors :D
Storm4200
2,912
NJ
firefighter7017 said:
One of the best POV's ever. I love it.
wow im humbled. thank you!
make sure you guys watch this video in HD
Storm4200
2,912
NJ
the flashing Duallys are tied in with the flashing takedowns on the ILS, on the same push button.
Storm4200
2,912
NJ
OK, the transition from RED/BLUE, to an ALL BLUE lighting set-up has reached completion.
All R/B lightheads have been changed to B only. The 2 LINz6s and the TIR3s are synced with the end pods of the TIR6 Traffic Advisor. The SS2000SM ground switches all of the TIR6s on the T/A. So i tied all of the grounds of the LINs and TIRs to the end pods on the Signal Master on the SmartSiren. So now the blues can only be activated if the two ends pods on the TA are flashing.
heres a video of some different rear patterns i can select on the fly, from the control head.
Storm4200
2,912
NJ
so i currently have 90w clear strobes in the reverse lights. Im looking to replace them with Whelen LAWs so i can sync them with the rest of the lights. My question is: WHAT COLOR?
the strobes have their own push button on the SS. I like to activate them when i have the Amber T/A on to the rear, so i dont think i want to do them in blue.
i like the white to the rear as it contrasts nicely with the amber and blue, during the day, Not at night.
If i did them in RED, i could still run them to the rear with the ambers only.
If i did them in amber, it would look great with the blues on, or with just the amber on, however no contrasting 'pop' of a different color.
so what do you guys think?
153
Lawrenceburg, KY
The new Setup looks Great! You honestly have the best POV setup I've ever seen. In both looks, Functionality, and how well thought out it is. Awesome job! :thumbsup:
Storm4200
2,912
NJ
well thank you sir. that means a lot. This board can be a tough crowd
Jul 24, 2012
153
Lawrenceburg, KY
No problem! Btw, I think amber LAW's would look great in the reverse lights.
Storm4200
2,912
NJ
now that i think about it....i dont think i can use Whelen LAWs, because the way im ground switching them to flash, theyre not going to work with the power supply they come with. This means id have to use Vertex or something similar, which im reluctant to do...
Jul 24, 2012
153
Lawrenceburg, KY
Is that because the vertex are bit weak in output? I hear the Soundoff undercover LAW's are pretty nice, they're plenty bright, and they come with the 3 different lenses to spread the light best in Your specific taillight housing. If you're using a separate flasher you should be able to sync them with your current setup if I'm not mistaken. Food for thought. :)
Storm4200
2,912
NJ
That's it exactly. The only hide a away LEDs that have ever impressed me, have been the LAWS.
Jul 24, 2012
153
Lawrenceburg, KY
Well I think the Soundoff Undercover's would fill out the small area of the reverse lights very nicely, Especially if you used the right lens. Might be worth a try!
Nov 7, 2011
983
New England
awesome!! i like the duallys as a simulated "HLF". I have a code 3 9led HAW in each of my high beam housing set on a simgle flash alternating just like that. works awesome.
The ILS is a sickeningly bright bar. My city's traffic cars have them.
Looks great!
Storm4200
2,912
NJ
I just tried to take a night video, but the ILS is so bright, the camera can't figure out what's going on
pdk9
3,834
New York & Florida
I think u have enough amber to the rear (BTW very cool wiring job with how the blues flash on the center out mode).
I would either go with blue LAWs in the reverse lights (so you have a large, combined blue footprint from the toolbox down, which compliments the upper tier of amber) or, if u go with red, put them in the upper brake light housing (since it's larger than the reverse lights). Everything else is so nicely synced that I think you can honestly go with a pair of SOS LAWs in the reverse lights on their own pattern (without necessarily syncing them to the whelen lightheads); ie have the 2 blue undercovers in the reverse light housing flash simultaneously at their own rate.
For the rear toolbox, are those the same rect LEDs that you previously had on the sides, or are they additional lightheads?
Storm4200
2,912
NJ
On the sides they are additional RECTs. I originally had the RECT14s on the front bumper, (and still do) and I came into a pair of RECT13 that are now on the sides of the tool box. (remember I had originally wanted LINZ6s there). The 13s may end up coming off, and going behind the grill on my wife's Audi (we shall see)
Storm4200
2,912
NJ
NEW HD (1080p) Video that i just took in the park behind my house.
Suggestions? Changes? Thoughts?
acala91
1,662
FL
The best POV I've seen. I'd like to see what the rear fast flash would look like on signal alert.
The only change I'd like to see is the side lighting. An M4 would be awesome on the side of the bumper, then put the grill light son the tool box and a pair of M6s on the brush guard :D
hoisy71
258
Baltimore, MD
I would like to see the 4 rear blues on an x flash but other than that looks great! :thumbsup:
Storm4200
2,912
NJ
yeah, i think a X pattern will look better also. ill work on that..
as far as the M series light heads, i agree 100%. the Tomars that are on the sides of the PB and on the toolbox, have almost no off-axis.
what i really wanna do is:
M6s on front of push bumper
M4s or M2s on the Side of the PB
M7s on the rear of the tool box
and replace the TIR3s on the LP with the LINZ6s
Storm4200
2,912
NJ
im ground flashing the rear blues off of the SS2000SM's Signal master. So, when they're set to Sig Alert, they don't flash right. i tried it already.
acala91
1,662
FL
This would be AWESOME!
That stinks, but it still looks great as is.
Storm4200
2,912
NJ
I'd like to see the side lights synced together, and the takedowns synced with the duallys. Other than that it's perfect!
ok, the sides are gonna be tough, because im ground flashing all of the rear blues off of the Signal master. If i sync the front intersection to the side, they would only be able to be turned on if the rear blues are on. But....wait a min...i just realized, theres never a time when im running "code" per-say, with the rear blues deactivated. So i might as well sync them, and the grills too. This will work! Now when responding, i can have every perimeter light flash 'fast', and then i can slow them down while on scene. Well, it will be able to essentially do anything that i can make the two end pods on the TA do.
OK, so Operation: Full Sync commences as soon as it stops snowing! (why didnt i think of this sooner?? :duh: )
now as for the Duallys, they are currently flashed off of a whelen HLF. I have NO IDEA how i would sync them to the ILS with the SIM box, or to the smart siren either. Well, while being able to retain the steady burn function also...
as for the TDs in the ILS, they flash with the pattern of the bar, i dont think they can flash independently. Does anyone know if they can??
Note: I have the steady burning TDs in the ILS wired to the highbeam switch. so while on dark rural roads, its one easy switch.
Dec 4, 2011
1,126
US NC
I didn't really mean sync per-say, even thought that would be awesome. I was implying that you change the pattern on the ILS TD's to be more similar to the duallys as opposed to the variable pattern that you have now.
Advancedstreet
