txff914
If you clean the windshield and the bracket real good with alcohol wipes that should stick real good.
Blaine B. said:Try some of that solid plastic 3M Dual Lock velcro stuff. It is the stiff velcro used for iPass/EZPass/Sun Pass automatic tolling transponders.
You can still remove the light, but that velcro stuff is VERY solid and secure.
Suction cups always come off in the sun and heat, and probably an accident, too. My Garmin GPS mounts pop off every once and awhile when sitting out in the sun, even when the GPS is not attached.
I have only seen it in clear, but apparently it also comes in black.
[Broken External Image]:http://www.tapplastics.com/uploads/products/Dual_Lock-xl.jpg
NFD-102 said:Someone mentioned 3M double sided sticky tape, I have used that before but in the North where temperatures are changing every season it doesn't work as well.
cybercop said:I'm sure we all made positive suggestions and Feniex took the feedback from its users and came up with the design. Kuddos to Feniex for listening to their customers.
Zapp Brannigan said:This is what sets them apart from other manufacturers. Hear that \/\/ and C3 and FS??? A Manufacturer upfront and vocal, and listening to their top consumers???
THIS IS WHERE THE MAGIC HAPPENS!!! ELB BABY!!!! :2thumbs: opo:
SireLite said:I would of gone with lock suction cups similar to what they use on satnavs.
Jamey@NNE said:Some customers wont allow them in permanent installs.
foxtrot5 said:IDK if it's even possible, but I'd love to see a way to position the light then remove the protective film that's over the tape while it's still in position... kinda like rolling the film back over its self.
AutoDetailer said:Feniex, will this be the heavy duty 3m Velcro or just two sided tape, I think I missed that part. I can't imagine using something that doesn't allow removal for cleaning. I would also be concerned about people breaking glass pulling on it if the metal housing was used as a fulcrum. Finally, in your tests did you include extreme high or low temps?
AutoDetailer said:Well I would vote for suction cups hands down over just regular "Very high Bond" tape.
Feniex said:Jamey,
What if we did something like this? I ran some tests on this VHB Glass to Metal bonding tape today. Its crazy strong! Took 2 of us to rip the dash light off the window.
Pro: SUPER STRONG!
Con: You really only have one shot at getting it right :cry:
FYI* tape is shown in red but production models would use black tape.
-Nick
SireLite said:Are the lightheads adjustable once the dash light is mounted? As it would be a pain in the but if you had it stuck to the window only to find out that the lights are pointing too far down.
Jarred J. said:that tape works well but it does have a shelf life. I have a dual talon taped to my headliner trim in my f 150. the tape lasted 7 years before it no longer held.
Feniex said:Jamey,
Pro: SUPER STRONG!
-Nick
