Christ now I'm even more confused. The first PDF shows the cannon with four wires and two modes, and a really stupid way of synchronizing them (seriously just copy Whelen's sync wire already, is that so hard?). The second PDF shows setups with FIVE wires and THREE modes, and says they can run in a brake AND tail light configuration replacing a dual filament bulb. So which is it?kenton1979 said:They are on the website at $108 list.
More info and instructions...
http://feniex.com/literature/cannonim2135858158.pdf
http://feniex.com/literature/CannonDiagram557844231.pdf
Solvarex said:Christ now I'm even more confused. The first PDF shows the cannon with four wires and two modes, and a really stupid way of synchronizing them (seriously just copy Whelen's sync wire already, is that so hard?). The second PDF shows setups with FIVE wires and THREE modes, and says they can run in a brake AND tail light configuration replacing a dual filament bulb. So which is it?
There are tons of aftermarket bulbs, standard and LED. I doubt any of them are rated, and is it the bulb that gets rated, or the light assembly? They should offer some sockets for specific vehicles so they actually replace the stock bulbs.Strobesnmore said:So are these DOT approved if they are a direct factory replacement?
Jamey@NNE said:The five wire 3 mode will be version 2 and from what I understand out soon.
Any replacement bulb made by a reputable manufacturer like Sylvania will carry a DOT certification. If it doesn't it is not legal to use in the vehicle as per FMVSS. Enforcement is an entirely different matter with almost no rank and file grunt cop knowing about FMVSS and DOT, from ABCs. Some people believe that in a collision an astute lawyer/prosecutor would point to non-certified lighting as the cause of the accident regardless of circumstances. That's why Whelen will tell you their HALO system is ONLY for use in CVPIs; that's what Whelen had them DOT certified in.theroofable said:There are tons of aftermarket bulbs, standard and LED. I doubt any of them are rated, and is it the bulb that gets rated, or the light assembly? They should offer some sockets for specific vehicles so they actually replace the stock bulbs.
Famous last words...FEVER said:And as long as its bright no one is truly going to care.....
Solvarex said:Famous last words...
firefighter31 said:no no no famous last words around here are "Hey Ya'll watch this!"
FEVER said:..Feniex is your competitor so I'm sure you already pointed them towards feniex and we will all know very shortly
Doghouse said:I don't want to get involved in this debate , but I do like to see some lights that finally have a two wire input for various light options. I would like to see more of this. Ditch the flasher and give us stand alone lights that we can connect a flasher to that would enable us to sync everything the way we want it. And for the two or more color options, the same. I for one would love to have a cheaper/smaller light no matter what the form factor (three, four, six, TIR, LIN, ETC) that I can decide how to make work the way I like with multiple input options.
Jamey@NNE said:The steady burn on this head will be capable of hooking up to a flasher. for the dual colors you would just set the 2 modes to steady burn in each color and hook each to a different channel on your flasher.
SirenWorld.com said:You can also set the mode for "brake mode" and it will do the triple flash then steady on... would make a very Whelen looking flash pattern... all sync'd!
Jamey@NNE said:I dont think that will work with another flasher very well if at all...
SirenWorld.com said:They told us they had tried it and it worked, so I'll be interested to try it. The boot time on the light was like 0:00.01 so it's very fast compared to the Fairy, so in theory...........
FEVER said:I think he is saying u wont be able to hook the "brake mode" to an external flasher.
mpaine said:FINALLY!!!! Something I can install in my 325i and not wreck the sacred BMW look!
tom said:Went to place an order for a bunch and.. oh great, they've disappeared from the site.
