Feniex Cannons - Compartment Lighting > OVER HEATING!
JohnFireFan
323
Louisiana
I am using two Feniex Cannons in dual color red/white as rear hatch lights in a Ford Explorer. After test running the Feniex Cannons as solid colors for around 5-10 minutes the light go so hot that it burnt out some of the LEDs or something along those lines. I turned on the lights and let it sit for 5-10 minutes on solid white. Next thing I new the LEDs started blinking and would not stay solid. I quickly turned them off and let them cool down. I turned them on again this morning and now they work BUT one Feniex Cannons white LEDs are only working to half capacity/brightness. The red LEDs are at full brightness it is only the white LEDs in one Feniex Cannon that is not at full brightness. Anyone had previous experiences with this? I guess I should contact Feniex and get it fixed or replaced?
Reactions: Ballistic
uniden278
383
Winthrop, MA
My understanding is that the cannon is not designed to be steady burned for that long, and if any of the LEDs are shutting off this is a failsafe to prevent them from melting the housing. There are other options for this application.
JohnFireFan
323
Louisiana
How old are they, the newer models its ok to use 6 of the leds for steady burn, but also depends on the way they are mounted.
I bought them new in April of 2014, these are the three mode generation ones. How does it depend on the way it is mounted? I assume that you mean if it is surface mounted to a body of a vehicle the metal helps dissipate some of the heat from the LEDs? That's my guess.
These lights are absolutely amazing and the innovation and success of the Feniex products makes me want to support the brand 100%. We could spit this install and have a variety of manufacturers but this needs to be all Feniex products with the exception of the siren. After talking to some Feniex customer service representatives they have been more helpful, informative and knowledgeable about their products than the other big "W" brand. Customer service is always your number 1 priority and that my friend is how you successfully run a business that will outshine the rest.
sheazle
185
Missouri
Make sure you have a good ground. I had problems with a set overheating on steady burn, I had tied 2 of them into a factory ground wire designed for a couple 194 bulbs.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
They may not have adequate area for heat to dissipate.  Can you post pics of how they are mounted?
May 25, 2010
7,072
Tunkhannock, PA, USA
You could always get a small cooling fan and tie it into the lights so when the lights are ont the fan turns on and circulates air in the area the lights are mounted...
kitsune86
152
Texas
I agree with Boulder.  I'm going to assume that there are no adequate openings in that plastic interior cover, so all of the heat that the cannons generate gets trapped in there.
wilsonbr90
1,427
Corning, New York
Not only that but mounting them to a metal surface is in the design to act as a heat sync. Plastic is an insulator, that lighthead has no where to dissapate heat except to the air and itself.
Workaround would be adding a resistor inline to drop the voltage some. At a certain point the light should produce about no heat. Generally on whelen products its about 10v with about 75-80% output
Sigma Safety
western Canada
We do exactly the same thing, except we use these lights; http://tecniqinc.com/pages/products_e06silhoxarea.php .  They are red/white switchable (they do not have a switch ON the light, you need to add your own) and have a lifetime warranty.  Part # E06-WS0R-1 .  They are a lot cheaper than a Cannon, too.
Disclaimer - we are a Feniex distributor and use a lot of Cannons, but just not in this application.
Here is a quick picture of a pair of the Tecniq lights in a Tahoe (one of our local Ambulance supervisor cars)...
ff168577
766
Levittown, Pa
We do exactly the same thing, except we use these lights; http://tecniqinc.com/pages/products_e06silhoxarea.php .  They are red/white switchable and have a lifetime warranty.  Part # E06-WS0R-1 .  They are a lot cheaper than a Cannon, too.
I looked at these lights at the Pa Fireman's expo.  Awesome lights.
JohnFireFan
323
Louisiana
I saw photos of it but is there videos of it in action? and how do I purchase two? The website only allows me to send them a payment of my own denomination.
Sigma Safety
western Canada
Videos of a compartment light??
Contact Tecniq directly and they will refer you to a local distributor.
ph;  (269) 629-4440
email; sales@tecniqinc.com
JohnFireFan
323
Louisiana
As you may know I have had to two Feniex Cannons in red/white as my rear hatching lighting for the past several months.
I know that these are not designed to stay on steadyburn for a long time but for my application I only used them to grab equipment from my trunk and go... so they never stayed on steadyburn for more than a few minutes. Anyway one of the Cannons only puts out half the output it should now and it's really aggravating. I replaced the other Cannon a few months ago because of the same issue. Now the other side is only half working.
What is the best replacement for compartment lighting? I already have 1" holes cut out for the Cannons and a 2-position switch powered for red compartment lights and white compartment lights. Please keep in mind I want something BRIGHT and looks good. I really hate to see the Cannons go but sometimes you need change. lol.
*Side note - I am having a trunk tray made that extends out 36" from the rear of my vehicle.
bluestinger90
657
BC / California
Whelen and Soundoff Signal make white/red led lights;
http://sirennet.com/wh3s.html
http://sirennet.com/soecvdmltal.html
I don't believe there is anything out there that will utilize the 1 inch hole and is both white and red. The only product I've found suitable for steady burn and uses the 1 inch hole, are these wurton led pods. They use .300mA at 13.5v and don't produce much heat.
http://www.amazon.com/20031-Mounting-Hardware-Electrical-Connectors/dp/B00B3LJ19G/ref=sr_1_1?ie=UTF8&qid=1424556008&sr=8-1&keywords=wurton+led+pod
Reactions: Retired1
Retired1
1,912
Woodward County, OK
I used Whelen red LIN3s and they worked very well. They are manufactured with steady burn, in addition to flash patterns, so steady on use does not affect them adversely. I did not like the TIR3s. The LIN3s had much better off-axis light output to light up my cargo area.
http://www.whelen.com/auto/product?head_id=12&cat_id=74&prod_id=145
I had never seen the 3" Whelen compartment lights before bluestinger90 posted the link above. I believe I will give them a try. Thanks, bluestinger90.
pdk9
3,834
New York & Florida
My 2 favorites are the 3" Whelen compartment light & the striplite; the striplite isn't as bright & won't cover up the cannon holes as well, so I'd go with the 3" lights
Reactions: 336 and fleetcomm
fleetcomm
717
south of nowhere
I have used the 3" Whelen compartment lights and have been very happy with them. The cost is less or the same as the cannons.
Reactions: 336
JohnFireFan
323
Louisiana
The Whelen 3" compartment light has ground leads for both red and white LEDs, correct? My switches are already wired for positive. The light appears to only have 125 lumens which is not a lot of light. If any one has pictures please post em. Thanks!
fleetcomm
717
south of nowhere
I used one on each side and they are very effective.
Sigma Safety
western Canada
We use a ton of the Tecniq lights.  They are SUPER thin (1/4" thick) and surface mount.  They have red/white switchable light (no switch on the light, but you already have a seperate one anyway).
They are designed specifically for vehicle task lighting.  We generally use one or two of them under the hatch on SUVs and they are fantastic.  Not stupid bright, but at night they are more than enough, and they have a downward pattern so they don't shine into your eyes.  They are roughly equivalent to a 20watt halogen.
We go through hundreds per year and I've never had one fail.
Part # we get is E06-WS0R-1 .  You can get them in a huge variety of trim ring options, LED colours, etc.
You should be able to pick them up for well under $50.
Tecniq has a ton of work/task lighting options.  We use their Dragon lights as fire apparatus step (not ground) lights.  They do have an E10 series which we use as a ground light (NFPA compliant).
They also make warning and scene lights in the normal sizes.  I have sold a few of their 9x7 LED scene lights and they are really good, and an excellent price, PLUS lifetime warranty.   http://tecniqinc.com/pages/K-Series-Emergency-Ambulance-Police-Fire-Truck-Flasher-Scene-LED-Bright.php .
Their website is not completely up to date, so get their 2015 catalogue off their website and browse.
Nearly all their stuff is manufactured in their plant in Michigan.  I think the E06's are made in Taiwan.
Reactions: fleetcomm
JohnFireFan
323
Louisiana
Just what I needed! I'll order em' tonight and post pics whenever they come in. THANK YOU!
Reactions: wilsonbr90
slash9dotnet
491
Conneaut, Ohio
The downside of that is when those don't work out for him, he'll need to find something to fill 3" holes. lol
Reactions: PJD642
JohnFireFan
323
Louisiana
First let me start off by saying this... the new TecNiq lights physically look better than the Feniex Cannons but it does NOT out perform the Cannons. Although they do work for my application it is an EXTREME loss of output vs Cannons. The install looks good, clean and almost factory. Painted the chrome flange black in order to make it look factory fresh. Thanks for the input everyone!
Sigma Safety
western Canada
Yes, they are designed as work lights, not warning lights.  The upside is that you can actually use them in your application because they barely get warm, not surface-of-the-sun hot like the back side of a Cannon.  Don't get me wrong - I love the Cannons, but not for compartment lighting and that's not what they are designed for - just like the Tecniq lights shown are not for warning lighting.
For future reference, you can get them with a black flange (though it's a plastic flange) if you want.  If you get the chrome flange/trim-ring like I suspect you did, then it's a metal flange, though easy enough to paint.  I believe they also have white trim rings as well (again, plastic).
JohnFireFan
323
Louisiana
Tried to contact them but no replies or call backs. The only thing available online was the chrome that I saw. I painted the flange black but due to the colder temps. it didn't work out well so I had to take it off. Once weather warms up I'll re-paint them.
*Future reference - buy the sold white LEDs for brighter output not white/red unless you absolutely need red lighting.
bobbyj
298
Bellingham, MA
Sorry to bring back an old thread but I'm having the same problem with a couple of cannons I have mounted as my cargo lights on my F150.  I have mine grounded just as you say to the factory wiring.  Did changing your ground help the problem?
Thanks,
Brandt
sheazle
185
Missouri
I had no problems with overheating after I added a better ground, but I also changed the way they were mounted so they were mounted to a piece of 1/8" aluminum instead of plastic.
JohnMarcson
May 7, 2010
10,971
Northwest Ohio
Any steady burn LED should be mounted so the heat sink contacts metal.
Reactions: sheazle and tsquale
GSPS629
