We have a 2000 Hackney heavy rescue with all halogen lighting. There are 2 main flashers, one does the upper lighting and the other the lower, which is eight 600s and two 900s. The problem is that they have been working for a few minutes, then they cut out, then they work again. I got to the whole board where everything is wired; the problem is that the relay (40A) and breaker (20A) are getting extremely hot, which causes them to overheat and cut out. What I can't figure out is why they are doing this, especially because they're mounted in a Class 1 circuit board, so all the connections seem good.
Does anyone have any ideas? I'd rather not have the rescue burn down.
