SirenO, The Original Vehicle Siren
Skulldigger
1,741
1,773
Georgia / USA
www.youtube.com
I just picked up this Sireno No. 5, known as the SirenO. The Sireno company was started in 1908 by John Gordon, Jr. and Charles H. Conner. Their patents of Feb. 4, 1908 and July 28, 1908 created the SirenO siren. It is small, with a chopper of just 3-7/8" in diameter. Including the projector it is 12" long.
As it arrived. The chopper would not spin.
Disassembly for cleaning
DSC_0983 (Small).jpeg DSC_0984 (Small).jpeg DSC_0985 (Small).jpeg DSC_0986 (Small).jpeg DSC_0987 (Small).jpeg DSC_0988 (Small).jpeg DSC_0989 (Small).jpeg
Cleaned parts
DSC_0990 (Small).jpeg DSC_0991 (Small).jpeg DSC_0992 (Small).jpeg DSC_0993 (Small).jpeg DSC_0994 (Small).jpeg DSC_1003 (Small).jpeg
Reassembly
DSC_0996 (Small).jpeg DSC_0997 (Small).jpeg DSC_0998 (Small).jpeg DSC_0999 (Small).jpeg DSC_1001 (Small).jpeg
Sì, video!
Is it 6 or 12 volt ??
It is 6v, from the serial number I'm estimating it was made between 1920 - 1925
Great job. Did you polish all the metal? What did you use? Does it work now? Video??
This was originally all nickel plated brass. I used a brass brush in my drill press to polish up the siren housing. The nickel was already flaking and coming off. Used the same brush on the chopper and the rear cover. The cone I dipped in PH down acid for about 3 hours and it cleaned up real nice. It does work! I will try and get a video before today is over. Being able to clean the motor and lubes, it spins great.
The horn shaped thing is the air intake. All the sound comes out of the chopper.
RE: the bearing, check your area for bearing suppliers (even in Fort Smith, AR we have a company that can find almost any bearing or bearing parts you might need). If it was originally nickel plate, you should consider the same—a good shop can recreate that for you. It’s much “warmer” than chrome plate, but require a bit more polish maintenance. Well worth it IMHO. Great addition to the collection!
Reactions: Skulldigger
raygames122333
