For the Feniex Dealers asking questions, here is the official Feniex description:
• 5 year warranty
• All in one controller
• Input Voltage: 11-16 VDC
• 18, back-lit, push-feel buttons
• 4 position programmable slide switch
• Includes U-shaped aluminum bracket
• Integrated traffic advisor with 8 outputs
• Implements rugged, solid state relays
• 8 positive (+) or ground (-) activated inputs
• 17 programmable outputs: 10 Amps (+)
• 1 programmable outputs: 3 Amps (-)
• 2 programmable, 4 output groups: 20 Amps
• 1 programmable 4 output continuous current: 30 Amps
• Integrated 2 channel Wigwag/LED flasher rated at 3 Amps
• Includes wire connectors for easy installation
• USB port provides easy access for programming
• Includes 50 standard function labels per button
• Dimensions of power supply: 6" L x 4" W x 1.5" H
• Dimensions of controller: 6.8" L x 3.5" W x 1.3" H
• Programed using our Feniex designed Windows application
• Back-lit LEDs can be adjusted for day or night time use
• Compatible with all other lighting and vehicle equipment
• Ability to program buttons as: On/Off, Momentary, Timer
• Bluetooth add on allows for phone or tablet wireless control
• Color coded back lit LEDs (Red indicator for on/Green for off)
• Includes 15 ft of RJ-45 cable from controller to power supply
and the schematics
Notice the ground controlled arrow
