Starting over. 2009 Explorer
Eric1249
2,277
Waukesha WI USA
I am leaning towards the clear as well. I was thinking a 30 single row Lifetime light
under the cross bar and if I went clear they might blend together as well. I just went out and did a video with a white T6 on the sides of the brush guard. But eventually my truck will be all red. Well except for the amber that will be in the reverse lights.
FusionWolf
504
Massachusetts
If you're going with another clear lenses led bar I'd definitely go with clear lens will help it blend in more. The t6s looks sweet on the side though!
Eric1249
2,277
Waukesha WI USA
Nice job syncing everything
Thanks. I was thinking about setting everything to the fastest possible pattern and seeing how many guys love it on some of the Facebook pages. lol.
The white Cannons in the fogs are not synced. But I am leaning to making everything red and
then they will be synced as well.
Eric1249
2,277
Waukesha WI USA
Amber Cannons ordered for the reverse light housing. Then the reds that are in there now will
go into the fogs. Cobra dummy's ordered for the sides of
the brush guard. One red to be synced and a white to be used like a alley light. Waiting for the Cannon
360's to come out.
I am going to get amber/white for the front turn signals. They
will be used for park and turn function. White will be used in place of a HLF. And I will also run an external flasher used for amber warning when needed for work.
Had brackets made ( I ended up cutting them down a little) and started remounting the PowerArcs
Reactions: tsquale
hfdemt4095
492
Holliston ma
360's to come out.
Are you replacing the whites that are in the fogs with the red, or adding to the fogs
hfdemt4095
492
Holliston ma
replacing the white in the fogs with red. Then the red will be synced
I don't think I am liking the look of the PowerArcs so I might replace them with a a pair of
Lightforce lights.
I would say add them to the sides of the push bumper...... But you already got that covered
Eric1249
2,277
Waukesha WI USA
Added amber Cannons to the rear tails. Not to sure I like it? Waiting on more dummy T6's for
the interior bar (replacing two of the older ones) and sides of the brush guard. (alley and
warning) Changing the white Cannons in the fogs to red possible this week. I also ordered
a pair of Lightforce for the brush guard.
Once the Cannon 360s are out I am going to get amber/white for the front turn signals. They
will be used for parking lights, turn signals, white flash for warning and amber warning for
work when needed. (using diodes)
Looking for opinions. I am thinking a Cobra 600 on the brush guard. Do I sync it with
everything else or keep it on a random pattern?
Eric1249
2,277
Waukesha WI USA
So I started changing things a bit. I started with the white and red dummy T6's on the sides of the brush guard. Just in case I wanted to ever change what is on the side I made a bracket
so that I only needed two holes in the brush guard. So if I change lights I just need to make a different bracket and match the holes. Hopefully tomorrow the Light Force lights will be here and I can see what it looks like. I threw a Cobra 600 on the brush guard the other night. It was synced with my other lights. Maybe too much light and too much sync? I took a video bit it was at night. I threw a couple of T6's in the grill and it looked pretty good.
Reactions: TritonBoulder47
woobatu
