Quote from above wanker's video:
Strobes in my denali and the reason i dont have them anymore i used them alot when i shouldnt have been,, :(
(old video for 2007)
Really? "I used them alot when I shouldn't have." Maybe because you probably got caught with them on once and was given more than just a warning to get rid of them:rolleyes:. What a box of tools...
Ben E. said:
Saw this in the Menards parking lot a few days ago. I have no idea what the shell is for the lightbar, but it looked like a real lightbar probably existed in there at one point, now it's just the frame/domes/center filled with teardrop rotators. It had some 120v bundled wire powering it that was screwed to the body of the cab. The mount on each corner was 2 metal 'L' brackets screwed together on the long part. Then the bottom L was screwed into the top of the cab, and the top L was screwed into the bottom of the lightbar.
wow
deleted... something that was dredged up from the past.
Here are two that just came in today.. The first is a large metropolitan county sheriffs police deparmtent car. It was on the road 3 days. This is the fine quality work that their own shop does. We have the contract to install locking gun racks in the cars. Why they cant do it . I dont know.. The fuses are all crimped with yellow and red butt connectors onto the factory plug. Then looped and stuffed behind the mat. The 1" hole in the firewall is not siliconed even though its has 2 8g and the power wire for the Justice bar running through it.
Next fine piece of workmanship is a DHS ICE 2008 Impala. It came in to the shop because it was broken into and had the slimlighter in the front, rear and SFGH100 control head stolen out of it. They didnt touch the Motorola Astro W3 head... It also had a non working sound off gemini supply.I vacumed out the broken glass, replaced the slimlighters and SFGH head and cable. The supply had totally shut down but was getting power to the turn on wires. A process of elimination of taking all 4 the cables off revealed a bad tube in the passenger side headlight housing, So far a no brainer.. Until I took the headlight out and found they had used about a half a tube of clear silicone to hold the tube in and seal the 2" hole in the outer housing. I scraped as much as I could out and vacumed out the tons of remaining silicone. the tube had totally burnt up the bottom of the base of the push in tube. It was repaired and put back into service. While under hood. I found this Gem. Everyone here knows that Federal makes a vehicle specific speaker for the Impala Right? You just drop it in under the drivers side headlight and mount it. Its a 5 minute job. Well apparently the fine installers who are in the custody of the federal goverment feel that its easier to go though the hassle of making their own bracket to mount the speaker facing up into the hood and wedging it in there so its next to impossible to get out. I thing cutting the hood isulation blanket is a nice touch too.. I wont mention who built this car but those in the know can figure out who it is. U N I Can Only Repair their mistakes.
Hahaha, figures. Can't do the right things most of the time anyway;).
fedsig7 said:
actually, that was a factory federal signal option, in the bar I have, a factory equiped Portland Police bar, there are upper level rear flashers, upper level takedowns, and dynarays, there are special brackets that move the rotators back so there is enough room for the dyna rays.
these bars were offered like this with a speaker section.
My bar has upper level rear amber flashers, red and blue front and rear lower flashers and 4 rotators .
Jtsou said:
He lives in eastern NC too? Oh God...why...
I'm nearly at a loss for words... Nearly. That's impressive for me, because I almost always have a smart-assed opinion to give. I know a few people like this guy. Scary to know they're spread so far and wide. lol.
On a side note, I have what appears to be the same dash light from STL (except my pattern button is on the other side) and it actually is a bright little light. I've not had any issues other than a couple of random pattern changes in the 2 years I've been using it. (Yes I know STL is hated on here, I bought them before I found ELB, and they haven't broken yet so they're still there.)
I've been wanting to take a picture of this truck for a while. It was finally in the yard today when I went to go gas up the hog of a truck I drive at work.
I guess that's a quick disconnect? :duh: :haha: :haha: :haha:
Quentin said:
Seen this at Wal-mart today. It looks like it's bolted to to the wood. The roof racks push together to hold down the bar and only one cable strap. ......
When I get home from work I have to search my old phone. There was a Durango that was at the local walmart here in Dutchess County NY. It had a Mini Whelen Edge with red/amber lenses.....
SBFD-E-9 said:
I don't think I've seen this one on here yet:
http://www.youtube.com/watch?v=ER3gilMc21k
Dan
Sorry you fail as this is a repost and disabled embedding because I do not want it embedded.
So what is wrong Retired1 install??????????
Not drilling a hole in the roof so it holds it's resale value by running the lightbar cable down the back so it could be easily removed and keep the value of the value of the truck. I fail to understand what you think is so wrong with the truck when everything is clean.
The truck was used by a Police Officer for road side construction duty and the amber Liberty was changed over from red/blue. These Police Officers will run more lights working these off duty jobs so they cab be seen. This is nothing out of the ordinary for these Police Officers, the lights are these for the safety of the construction workers.
I've seen that truck. It has no front parking lights and a I <3 MATLOCK bumper sticker.
I never said there was anything wrong with the install work itself. That actually looks very well done. I just fail to see why it needs two lightbars, plus other LEDs mounted to the bumper.
Now, I will say I didn't notice that it is a demonstration vehicle before I posted it, which makes it a little better. Me posting it wasn't meant to offend anyone. You just don't see a pickup truck with two lightbars everyday...
Dan
Originally passed by this beauty on an adjacent roadway and thought that I saw some after-market "somethings" on the rear deck but I'm still not sure due to direct sunlight. I really don't have a clue and I apologize for not getting photos of the rear of this vehicle as I felt very, very compelled to exit this parking lot shortly after snapping these photos. But hey, it looked like an officially-marked vehicle which is why I stopped to check it out in the first place.
That being said... Have any central Ohio motorists here ever traded traffic-jabs with a maroon / dark red Ford Taurus sporting heavily-tinted windows and a Ford "Police Interceptor" decal affixed to the back of said vehicle?
if i was going to try to kill zombies i wouldnt use a vic.... at least one without a pushbumper anyways.
This is from the latest lame Steven Seagal tv show "True Justice". A visor-mount Whelen Slimlighter angled around 15* down, I think. Holy Flashback Batman on the dash. It serves as the only front lighting for a new GMC Yukon. Doesn't really count as "whacker" but maybe more of "screwed up"?
Might just be angled that way for a camera shot. If the LEDs were facing the correct direction it would be right into the camera and wash out the image. It's not uncommon for tv/film to "alter" lighting systems to still flash like it should but to avoid ruining a camera shot with too much light.
Found a real doozie locally on Craigslist!
Sweeeeet! LOL
2004 CUSTOM dodge Stratus - pilot,ems,fire,security,tow
2004 CUSTOM dodge Stratus - pilot,ems,fire,security,tow - $5799 (South Bend)
Date: 2012-04-09, 5:47PM EDT
Reply to: s8xzf-2949099963@sale.craigslist.org [Errors when replying to ads?]
I have up for sale my Custom 2004 4 cyl. Dodge Stratus Se 4 door Silver in color.
Auto has 94,000 miles
I have had this auto on the road for the last 3 years doing Auto Service work helping motorists and have added many features to the auto for that as well as volunteer work I do with various agencies and also put some features for camping / personal use.
This auto has taken about 600+ hours of work to get to the way it is today. I had to strip the interior and rebuild it and do a lot of custom work to it.
This auto has gotten me several 1st place ribbons and trophies for best custom at car shows in my area.
Equipment list includes:
1) Setina Custom painted front push bumper.
2) dual 100Watt Galls front speakers and Whelen Air horn / Pa system with 100 watt 3rd speaker for broadcast.
3) 2 - Yellow Federal Signal GH lights ( currently hooked up for fog lights ).
4) Galls BU192 hide-a-way strobes ( yellow ) in both headlights.
5) Unity spotlight with black rubber housing.
6) Left and Right side front fender side marker led turn signals
7) 2 - Under hood work lights
8) Quick Connect battery connector ( cables not included )
9) K&N air filter
10) Sears Die Hard Platinum battery put in 01/23/2010 ( was $190.00 ).
11) New plugs, wires and ignition put in on 12/13/2010 ( was $225.00 ).
12) 4 - snow tires with about 10,000 miles on them ( currently on car ).
13) 4 - all season tires not bolted or on rims - about 7/8,000 miles left on them as measured by Discount Tire.
14) 2 - Motorola 1/4 wave antenna ( 1 on roof - 1 on trunk ).
15) 1 - Wilson 5000 Cb antenna.
16) 2 - Sound Off Signal 6" oval clear back up lights ( very bright ).
17) 2- Sound Off Signal Tir3 Yellow lights on rear.
18) Rear custom striping.
19) 2- Whelen LIN3 Yellow led lights on Driver and Passenger Mirrors.
20) 2 - Whelen Tir3 Yellow led lights on left and right side rear side fenders.
21) Right side rear rv cap for running extra cable out for Ham radio gear.
22) Left side rear rv cap for custom made 2 ul outlet for aux power for camping or emergencies from onboard 350 watt convertor.
23) Phaze brand gauge cluster with Vac and oil pressure gauges.
24) Galls 9 function switch box with slide.
25) Galls 6 function switch box.
26) Dakota Digital outside temp guage.
27) Reverse Alarm with switch to overide.
28) Rear View 7" back up camera with 3 viewing angles and Dvd input.
29) Bravo brand Dvd player
30) 1 1/4" Hitch
31) Sound Off Signal red oval headliner light with on/off/auto
32) Galls traffic backer
33) 2- Galls GR200s Deck strobes
34) Galls strobe power supply for the front and rear strobes.
35) 6" oval headliner led red interior light
36) 6 white led interior lights / replaced the incandesent.
37) Galaxy 979 Cb with uppers and lowers.
38) Texas Ranger Digital Frequency Counter ( not currently hooked up but works ).
39) Pioneer brand Driver and Passenger headrest 16:9 monitors for Dvd or reverse camera viewing.
40) XM radio receiver unit ( no subscription )
41) Pioneer am/fm/xm/cd changer control / player / main control unit with single cd player and detachable face.
42) Pioneer 12 disc cd unit cdx-p680 ( missing 12 disc cartridge ).
43) Pioneer Gm-3100t 2 channel power amp.
44) Kenwood KAC-642 4 channel amp.
45)Kenwood KAC 8401 640 watt multi channel amp.
46) 9 speakers - 2 in front doors / 2 in rear doors / 2 in rear deck / 2 in trunk for tail gaiting and sub.
47) Infinity Bass Link sub with amp.
48) Digital 1000 capacitor.
49) Aux cig light plug in trunk.
50) 6 trunk area led lights with on / off switch.
51) rear seat UL outlet connected to 350 watt invertor.
52) Internal roll cage.
53) Red Led gooseneck map light mounted on front passenger side.
54) Inside trunk mounted 55watt work lights so you can open the trunk and work on a car behind you.
55) Federal Signal Traffic Direction Arrow 8 lamp with right and left end overides attached to the brake lights for added deck mount brake lights.
56) Manuals and records for all equipment and work done.
Auto runs and drives well.
Known Issues:
1) I just found out through a showing that the passenger side rear window is working very slowly and I would guess may need a new motor in the future.
2) Oxygen sensor sends an error message about every few months and I have to disconnect the battery for about 5 min to reset it. Dodge has replaced it twice and is not sure what is making the error still.
3) various holes were in the roof when I received the car from a firefighter and have been RTV filled but the roof is no longer smooth due to there being about 9 small holes from direct mounting of his lights and 4 from the mounting of my light bar that will need to be filled and or plugged unless your using a Whelen light bar yourself?
4) Rear deck strobes are RED and I will not sell this with the red lenses unless you can prove affiliation for having the red lenses. You can get other colors via Galls / Ebay or your local provider.
NOT INCLUDED WITH SALE BUT IN PHOTOS:
1) all ham radio gear and rear deck antenna but am open to sale of this for extra.
2) Whelen brand light bar on roof.
3) Front Dominator light.
I have described this auto as best I can but if you have any questions, I would be happy to talk with you or if you care to come and take a look at it, I would be happy to set up a time when we can meet and I would be happy to go over all the functions with you.
I am currently in Grand Rapids, Michigan with the auto.
[Broken External Image]:http://images.craigslist.org/5I85G45K13M63F13N6c49a9fe60f04cd314b0.jpg
[Broken External Image]:http://images.craigslist.org/5F35M65J93G13M43Nac494c3eef95c155193c.jpg
[Broken External Image]:http://images.craigslist.org/5N55I85P53L63me3Mdc493e0a6ff55df51837.jpg
[Broken External Image]:http://images.craigslist.org/5Ic5H25Je3n53Ia3Jfc496aa777e8e9ad140a.jpg
i think thats been posted on here a few times
Ronaele
