Catalog Collection
I recently received these from member @ropersupplyco and told him that I would get them scanned in to share with you all. Some cool literature including a catalog and their dealer newsletter.
  • 911ep 360star.pdf
  • 911ep cat color.pdf
  • 911ep flashpoints summer 2003.pdf
  • 911ep galaxy components.pdf
  • 911ep flashpoints summer 2006.pdf
  • 911ep galaxy order form.pdf
  • 911ep mounting options.pdf
I was looking through my hard drives and came across the 2003 911EP catalogue.
Unfortunately not the one with the ”flying sourcer” beacon that could be mounted on top of their roof bars.
I also found the 2004 911EP catalogue that is the same as the one that Tony P posted but this is the original downloaded one from 911EP’s web
Michael
  • catalog_2003.pdf
  • catalog_2004.pdf
1971 Yankee Catalog. Looks like emergency lighting was something they were just getting into. Didn't even have the 1166 teardrop lights yet. Most of this edition of their catalog was side-view mirrors.
Emergency lighting from the KD's 1988 catalog.
1970, 1971
  • Image_00003.pdf
  • Image_00004.pdf
  • Image_00005.pdf
  • Image_00006.pdf
  • Image_00007.pdf
  • Image_00008.pdf
  • Image_00009.pdf
  • Image_00010.pdf
JPG versions of those early 70s pages.
1976: I'd posted these before the big switchover.
SIGNAL LIGHT MEANS COMPRISING AN ELONGATE HOLLOW MOUNTING BAR; A PAIR OF SIGNAL LIGHTS MOUNTED ADJACENT THE OPPOSITE ENDS OF SAID BAR; EACH LIGHT COMPRISING A BASE, A LIGHT TRANSMITTING DOME ON THE BASE, A SHAFT JOURNALLED ON THE BASE AND EXTENDING UPWARDLY INTO THE DOME AND DOWNWARDLY INTO SAID BAR, LAMP MEANS ON THE UPPER END PORTION OF SAID SHAFT WITHIN SAID DOME, AND SPROCKET MEANS ON THE LOWER END PORTION OF SAID SHAFT WITHIN SAID BAR; A MOTOR IN ONE OF SAID LIGHTS DRIVINGLY CONNECTED TO THE SHAFT THEREIN; A PARTITION WITHIN SAID BAR IMMEDIATELY BELOW AND EXTENDING BETWEEN SAID SPROCKET MEANS; CHAIN MEANS IN SAID BAR ABOVE SAID PARTITION REAVED OVER SAID SPROCKET MEANS FOR IMPARTING THE MOVEMENTS OF THE MOTOR DRIVEN SHAFT TO THE OTHER OF SAID SHAFTS; SAID BAR FITTING CLOSELY ABOUT SAID SPROCKET MEANS WHEREBY SAID BAR AND SAID PARTITION PREVENT DISASSOCIATION OF SAID CHAIN MEANS FROM SAID SPROCKET MEANS; AND POWER SUPPLY MEANS FOR SAID LAMP MEANS AND SAID MOTOR EXTENDING THROUGH SAID BAR BELOW SAID PARTITION.
Abstract​
A warning light assembly is provided that includes a simple drive train for accomplishing an 180° or more oscillation of a light beam. By advantageously utilizing a speed-reduction mechanism, a transmission for converting rotary motion to oscillating motion and a coupling for multiplying the angle of oscillation, the drive provides an inexpensive and rugged enabling design the warning light assembly to oscillate a light beam through angles heretofore unattainable.
A flashing signal light that includes a rotatably mounted signal generator formed of a light transmitting material and a non-rotatable source of light adapted to direct light into the generator along its axis of rotation. A pyramid shaped prism is associated with the generator having its apex positioned along the axis of rotation. The prism surfaces intercept the light directed into the generator, split the light into one or more beams and direct the beams towards the exit face of the generator in a plane that is substantially perpendicular to the axis of rotation.
I bid on this catalog like crazy On eBay. Once it got over $36 I was out. But the screenshots are worthy of sharing here.
These are from a 1978 issue of JCW. I looked forward to my free copy every month as a kid. Until they dropped warning lights almost entirely in the late 1980s.
Reactions: Tango7
1982 JCW
This thread is a compilation of posts that still had viewable content from all of the old catalog threads. The old threads have been locked but are still viewable at the links below.
runninwithdiesel
